Arduino + PHP = retornar valor do reolê?
Amigos, boa tarde. Sou novo com arduino, e estou com uma dúvida!
Eu tenho um código onde ligo e desligo o relê, pela internet e queria saber como fazer o PHP recuperar um valor do arduino!
Arduino.ino
#include <SPI.h>
#include <Ethernet.h>
 // Dados da rede
 byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
 byte ip[] = { 192, 168, 1, 99 }; // Ip do arduino
byte gateway[] = { 196,168, 1, 1 };
byte subnet[] = {255, 255, 255, 0};
EthernetServer server(81); // Porta do arduino
int pin = 5; //RELÊ NO PINO 5
  Ethernet.begin(mac, ip, gateway, subnet);
  server.begin();
  delay(1000);
  Serial.println("Setup complete");
  pinMode(pin, OUTPUT);
  digitalWrite(pin, LOW);
void loop ()
EthernetClient client = server.available();
if (client) {
  Serial.println("Cliente conectado");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.print(c);
        //Execute code based on the package the server sent
        if (c == '1')
         Serial.println("ON");
         digitalWrite(pin, HIGH);
        if (c == '0')
         Serial.println("OFF");
       if (c == '9')//Check the state of Pin 7 and send that to the connected clent
         Serial.println("CHECKSTATUS");
         if (digitalRead(pin)== LOW)
           {server.write("OFF");}
         if (digitalRead(pin)== HIGH)
           {server.write("ON");}
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("Cliente Desconectado");
PHP
<?php
$sock = socket_create(AF_INET, SOCK_STREAM, SOL_TCP);
// Se conecta ao IP e Porta:
socket_connect($sock,"192.168.1.99", 81);
if (isset($_POST['ligarele'])) {
    socket_write($sock,1);
if (isset($_POST['desligarele'])) {
    socket_write($sock,0);
if (isset($_POST['verifica'])) {
    socket_write($sock,9);
<html>
<script src="https://ajax.googleapis.com/ajax/libs/jquery/1.12.4/jquery.min.js"></script>
<body>
<form action="" method="post">
<input type="submit" name="ligarele" value="Liga Relê" />
<input type="submit" name="desligarele" value="Desliga Relê" />
<br />
<input type="submit" id="ver" name="verifica" value="Verifica Relê" />
</form>
<div id="content"></div>
</body>
</html>
Desde já agradeço!
Não entendo muito de PHP, mas quando fiz algo semelhante com Python, criei uma função para recuperar os valores que seria algo do tipo:
Serial.write(digitalRead(pin))
No PHP, haveria uma função para resgatar esse valor da porta serial e imprimir no sistema.
Sim, eu já consegui!
Obrigado!!
