Problemas na qualidade na impressão 3D
Bom dia Pessoal,
Estou tentando imprimir um aeromodelo que esta disponivel no site https://3dlabprint.com/ é so uma peça de teste ainda nao comprei o projeto deles justamente para ver o desempenha da minha impressora com essa peça, primeiro tinha feito uma em material ABS, ficou muito ruim, ai fiz em PLA ficou muito melhor mais ainda assim preciso melhorar,
Abaixo segue setup sugerido por eles:
[profile]
layer_height = 0.25
wall_thickness = 0.4
retraction_enable = True
solid_layer_thickness = 2
fill_density = 0
print_speed = 60
print_temperature = 200
print_temperature2 = 0
print_temperature3 = 0
print_temperature4 = 0
print_temperature5 = 0
print_bed_temperature = 70
support = None
platform_adhesion = None
support_dual_extrusion = Both
wipe_tower = False
wipe_tower_volume = 15
ooze_shield = False
filament_diameter = 1.75
filament_diameter2 = 0
filament_diameter3 = 0
filament_diameter4 = 0
filament_diameter5 = 0
filament_flow = 102.0
nozzle_size = 0.4
retraction_speed = 40.0
retraction_amount = 0.7
retraction_dual_amount = 16.5
retraction_min_travel = 1.5
retraction_combing = Off
retraction_minimal_extrusion = 0.02
retraction_hop = 0.0
bottom_thickness = 0.3
layer0_width_factor = 120
object_sink = 0.0
overlap_dual = 0.15
travel_speed = 150.0
bottom_layer_speed = 20
infill_speed = 0.0
solidarea_speed = 0.0
inset0_speed = 0.0
insetx_speed = 0.0
cool_min_layer_time = 5
fan_enabled = False
skirt_line_count = 1
skirt_gap = 0
skirt_minimal_length = 150.0
fan_full_height = 0.5
fan_speed = 100
fan_speed_max = 100
cool_min_feedrate = 10
cool_head_lift = False
solid_top = False
solid_bottom = False
fill_overlap = 15
perimeter_before_infill = True
support_type = Lines
support_angle = 60
support_fill_rate = 15
support_xy_distance = 0.7
support_z_distance = 0.15
spiralize = True
simple_mode = False
brim_line_count = 20
raft_margin = 5.0
raft_line_spacing = 3.0
raft_base_thickness = 0.3
raft_base_linewidth = 1.0
raft_interface_thickness = 0.27
raft_interface_linewidth = 0.4
raft_airgap_all = 0.0
raft_airgap = 0.22
raft_surface_layers = 2
raft_surface_thickness = 0.27
raft_surface_linewidth = 0.4
fix_horrible_union_all_type_a = False
fix_horrible_union_all_type_b = False
fix_horrible_use_open_bits = False
fix_horrible_extensive_stitching = False
plugin_config =
object_center_x = -1
object_center_y = -1
[alterations]
start.gcode = ;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
G92 E0 ;zero the extruded length
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing…
end.gcode = ;End GCode
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
M84 ;steppers off
;{profile_string}
start2.gcode = ;Sliced at: {day} {date} {time}
;M104 S{print_temperature} ;Uncomment to add your own temperature line
;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line
;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
T1 ;Switch to the 2nd extruder
G1 F200 E10 ;extrude 10mm of feed stock
G1 F200 E-{retraction_dual_amount}
T0 ;Switch to the first extruder
G1 F{travel_speed}
M117 Printing…
end2.gcode = ;End GCode
M104 T0 S0 ;extruder heater off
M104 T1 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
start3.gcode = ;Sliced at: {day} {date} {time}
G21 ;metric values
T2 ;Switch to the 3rd extruder
G1 F{travel_speed}
M117 Printing…
end3.gcode = ;End GCode
M104 T2 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
start4.gcode = ;Sliced at: {day} {date} {time}
;M109 T2 S{print_temperature2} ;Uncomment to add your own temperature line
G21 ;metric values
T3 ;Switch to the 4th extruder
G1 F{travel_speed}
M117 Printing…
end4.gcode = ;End GCode
M104 T3 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
support_start.gcode =
support_end.gcode =
cool_start.gcode =
cool_end.gcode =
replace.csv =
preswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added before the T(n)
postswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added after the T(n)
Desde já, agradeço a atenção.
Algumas coisas que eu já passei e talvez possam ajudar:
  • A peça está aderindo corretamente na mesa? Quando ela entorta, às vezes obstrui um pouco do extrusor e o filamento não sai completamente, ocasionando falhas. Outra coisa de hardware que pode ser é o nivelamento da mesa.
  • Para evitar essas “bolhas” que sobram, o problema geralmente é aquecimento demais. Ligar a ventilação, aumentar a velocidade de impressão ou diminuir a temperatura do extrusor pode ajudar.
Sobre isso, um truque que me ensinaram é verificar a temperatura mínima de extrusão:
  • insira o filamento com o extrusor aquecido a 200 graus.
  • empurre manualmente o filamento. Ele deve sair constante.
  • diminua a temperatura de dez em dez graus até precisar fazer força para extrair.
  • quando você estiver fazendo um leve esforço, mas ainda estiver saindo, é a temperatura ideal.
Tente fazer, se possível, um teste de cada vez para ver o que realmente ajuda.
Boa sorte :slight_smile:
Os modelos da 3DLabPrint são projetados especificamente para PLA, não devem ser impressos em ABS.
Qual é o seu nível de experiência prévia com impressão 3D ? Esses modelos não são indicados para quem está começando a lidar com as impressoras 3D, pois os ajustes são bastante críticos.
