Ajuda com codigo basico
BOA NOITE AMIGOS
GOSTARIA DE UMA AJUDA COM ESSE CÓDIGO ABAIXO PRECISO ACIONAR COM UM BOTÃO DUAS SOLENOIDES DE CADA VEZ POREM UMA DELAS DEVE SE REPETIR NO BOTÃO SEGUINTE OU SEJA UMA
BOTÃO 1 ACIONA RANGE E FWD1
BOTAO 2 ACIONA RANGE2 E FWD1
BOTAO 3 ACIONA RANGE2 E FWD2
BOTAO 4 ACIONA RANGE1 E REV1
BOTAO 5 ACIONA RANGE2 E REV1
E ESCREVE NO DISPLAY CADA AÇÃO
INICIEI O CODIGO ATE ACIONAR O BOTAO 1 OK QUANDO ACIONO O BOTAO2 JA DA ZEBRA O DISPLAY NAO ESCREVE
#include “LiquidCrystal.h”
#include "Limits.h"
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); //essa é a pinagem LCD no UNO
const int buttonPin0 = 8; // the number of the pushbutton pin
const int buttonPin1 = 10; // the number of the pushbutton pin
const int RANGE1 = 13; // the number of the LED pin
const int RANGE2 = 6; // the number of the LED pin
const int FDW1 = 7; // the number of the LED pin
const int FDW2 = 9; // the number of the LED pin
// variables will change:
int ZERO = 0; // variable for reading the pushbutton status
int UM = 0; // variable for reading the pushbutton status
//Inicializando o LCD e informando o tamanho de 16 colunas e 2 linhas
//que é o tamanho do LCD JHD 162A usado neste projeto.
lcd.begin(16, 2);
lcd.clear(); //limpa o display do LCD.
lcd.print(" TECH CABANA "); //imprime a string no display do LCD.
lcd.setCursor(0,1);
lcd.print(“TEST TRANSMISSAO”);
delay(5000);
// initialize the LED pin as an output:
pinMode(RANGE1, OUTPUT);
pinMode(RANGE2, OUTPUT);
pinMode(FDW1, OUTPUT);
pinMode(FDW2, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin0, INPUT);
pinMode(buttonPin1, INPUT);
void loop(){
// read the state of the pushbutton value:
ZERO = digitalRead(buttonPin0);
UM = digitalRead(buttonPin1);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (ZERO == HIGH) {
// turn LED on:
digitalWrite(RANGE1, HIGH);
digitalWrite(FDW1, HIGH);
lcd.setCursor(1,0);
lcd.print(" HYSTER H155FT ");
lcd.setCursor(0,1);
lcd.print(“PRIMEIRA FRENTE”);
else {
// turn LED off:
digitalWrite(RANGE1, LOW);
digitalWrite(FDW1, LOW);
lcd.clear();
COMO FAÇO PARA ACIONAR O BOTAO 2 E ESCREVER SEGUNDA A FRENTE SE ME AJUDAREM A PARTIR DO TERCEIRO JA CONSIGO RESOLVER SOZINHO.
OBRIGADO
Seu código diz que se o botão ZERO não estiver acionado é para limpar o display…
