Preciso de uma ajuda
Estou tentando fazer o acionamento do rele pela internet abaixo esta o codigo que estou usando so que quando coloco o ip+/10 que é pra desliga o rele nao desliga ele smp fica ligado e quando estava usando um led funcionava
# include <ESP8266WiFi.h>
const char* ssid = “VIVO-8478”; //VARIÁVEL QUE ARMAZENA O NOME DA REDE SEM FIO EM QUE VAI CONECTAR
const char* password = “0703001315”; //VARIÁVEL QUE ARMAZENA A SENHA DA REDE SEM FIO EM QUE VAI CONECTAR
//DEFINIÇÃO DE IP FIXO PARA O NODEMCU
IPAddress ip(192,168,15,1);
IPAddress gateway(179,184,120,16); //GATEWAY DE CONEXÃO (ROTEADOR)
IPAddress subnet(255,255,255,0); //MASCARA DE REDE
WiFiServer server(80); //CASO OCORRA PROBLEMAS COM A PORTA 80, UTILIZE OUTRA
 int val1 = 0; //variáveis que definem o estado dos leds
 int val2 = 0; //
  delay(10);
  // prepare GPIO
  pinMode(4, OUTPUT);
 digitalWrite(4, 0);
  // Connect to WiFi network
  Serial.println();
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  WiFi.config(ip, gateway, subnet); //PASSA OS PARÂMETROS PARA A FUNÇÃO QUE VAI SETAR O IP FIXO NO NODEMCU
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  // Start the server
  server.begin();
  Serial.println("Server started");
  // Print the IP address
  Serial.println(WiFi.localIP());
  // Check if a client has connected
  WiFiClient client = server.available();
  if (!client) {
    return;
  // Wait until the client sends some data
  Serial.println("new client");
  while(!client.available()){
    delay(1);
  // Read the first line of the request
  String req = client.readStringUntil('\r');
  Serial.println(req);
  client.flush();
  if (req.indexOf("/10") != -1)
      val1 = 0;
  if (req.indexOf("/11") != -1)
      val1 = 1;
  if (req.indexOf("/20") != -1)
      val2 = 0;
  if (req.indexOf("/21") != -1)
      val2 = 1;
  digitalWrite(4, val1);
  digitalWrite(5, val2);
  client.flush();
  // Prepare the response
  String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nGPIO is now ";
  s += (val1)?"high":"low";
  s += "</html>\n";
  // Send the response to the client
  client.print(s);
  delay(1);
  Serial.println("Client disonnected");
  // The client will actually be disconnected
  // when the function returns and 'client' object is detroyed
![07%20PM|375x500]
Também gostaria de saber a solução, abraços
O problema é o rele o teu deve ser o simples que so tem um rele esse nao funciona
Ola,
pelo que vi, este módulo é um módulo de relay que trabalha com 5v (como a maioria) e o NodeMCU trabalha com 3.3v por padrão, logo, não passa energia suficiente para o Relê, então você precisa alimentar de forma diferente. Acredito que este exemplo te ajude. http://autocorerobotica.blog.br/aprenda-controlar-o-modulo-rele-com-esp8266/
