Olá tudo bem!
Está dando erro ao carregar este código para meu Esp8266 Generic, alguém pode me ajudar?
#include <Arduino.h>
#include <WiFiMulti.h>
#include <WebSocketsClient.h> // https://github.com/kakopappa/sinric/wiki/How-to-add-dependency-libraries
#include <ArduinoJson.h> // https://github.com/kakopappa/sinric/wiki/How-to-add-dependency-libraries
#include <StreamString.h>
#ifdef ARDUINO_ARCH_ESP32
#include <WiFi.h>
#else
#include <ESP8266WiFi.h>
#endif
#include “SinricPro.h”
#include “SinricProSwitch.h”
#define WIFI_SSID “SSID”
#define WIFI_PASS “password”
#define APP_KEY “xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx” // O seu App Key é algo como “de0bxxxx-1x3x-4x3x-ax2x-5dabxxxxxxxx”
#define APP_SECRET “xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx” // O seu App Secret é algo como “5f36xxxx-x3x7-4x3x-xexe-e86724a9xxxx-4c4axxxx-3x3x-x5xe-x9x3-333d65xxxxxx”
#include <AceButton.h> // https://github.com/bxparks/AceButton
using namespace ace_button;
WiFiMulti WiFiMulti;
WebSocketsClient webSocket;
WiFiClient client;
#define MyApiKey “Your_API_Key” // TODO: Change to your sinric API Key. Your API Key is displayed on sinric.com dashboard
#define MySSID “SSID” // TODO: Change to your Wifi network SSID
#define MyWifiPassword “PASS” // TODO: Change to your Wifi network password
#define HEARTBEAT_INTERVAL 300000 // 5 Minutes
uint64_t heartbeatTimestamp = 0;
bool isConnected = false;
// Switch
const int BUTTON1_PIN = 12;
const int BUTTON2_PIN = 13;
const int BUTTON3_PIN = 14;
//Relays
const int RELAY1_PIN = 4;
const int RELAY2_PIN = 5;
const int RELAY3_PIN = 16;
//Status LEDs
const int LED1 = 26;
const int LED2 = 25;
const int LED3 = 27;
String device_ID_1 = “5f94584e0a046d3259898305”;
String device_ID_2 = “5f945ebbece21732512247d1”;
String device_ID_3 = “5f945f10ece21732512247dd”;
ButtonConfig config1;
AceButton button1(&config1);
ButtonConfig config2;
AceButton button2(&config2);
ButtonConfig config3;
AceButton button3(&config3);
void handleEvent1(AceButton*, uint8_t, uint8_t);
void handleEvent2(AceButton*, uint8_t, uint8_t);
void handleEvent3(AceButton*, uint8_t, uint8_t);
void setPowerStateOnServer(String deviceId, String value);
// deviceId is the ID assgined to your smart-home-device in sinric.com dashboard. Copy it from dashboard and paste it here
void turnOn(String deviceId) {
if (deviceId == device_ID_1) // Device ID of first device
Serial.print("Turn on device id: ");
Serial.println(deviceId);
digitalWrite(RELAY1_PIN, LOW);
if (deviceId == device_ID_2) // Device ID of first device
digitalWrite(RELAY2_PIN, LOW);
if (deviceId == device_ID_3) // Device ID of first device
digitalWrite(RELAY3_PIN, LOW);
if (deviceId == device_ID_4) // Device ID of first device
digitalWrite(RELAY4_PIN, LOW);
void turnOff(String deviceId) {
Serial.print("Turn off Device ID: ");
digitalWrite(RELAY1_PIN, HIGH);
digitalWrite(RELAY2_PIN, HIGH);
digitalWrite(RELAY3_PIN, HIGH);
digitalWrite(RELAY4_PIN, HIGH);
void webSocketEvent(WStype_t type, uint8_t * payload, size_t length) {
switch (type) {
case WStype_DISCONNECTED:
WiFiMulti.addAP(MySSID, MyWifiPassword);
Serial.printf("[WSc] Webservice disconnected from sinric.com!\n");
break;
case WStype_CONNECTED: {
isConnected = true;
Serial.printf("[WSc] Service connected to sinric.com at url: %s\n", payload);
Serial.printf(“Waiting for commands from sinric.com …\n”);
break;
case WStype_TEXT: {
Serial.printf("[WSc] get text: %s\n", payload);
// Example payloads
// For Switch or Light device types
// {"deviceId": xxxx, "action": "setPowerState", value: "ON"} // https://developer.amazon.com/docs/device-apis/alexa-powercontroller.html
// For Light device type
// Look at the light example in github
#if ARDUINOJSON_VERSION_MAJOR == 5
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject((char*)payload);
#endif
#if ARDUINOJSON_VERSION_MAJOR == 6
DynamicJsonDocument json(1024);
deserializeJson(json, (char*) payload);
#endif
String deviceId = json [“deviceId”];
String action = json [“action”];
if (action == "setPowerState") { // Switch or Light
String value = json ["value"];
if (value == "ON") {
turnOn(deviceId);
} else {
turnOff(deviceId);
else if (action == "test") {
Serial.println("[WSc] received test command from sinric.com");
break;
case WStype_BIN:
Serial.printf("[WSc] get binary length: %u\n", length);
break;
Serial.println();
Serial.print("Connecting to Wifi: ");
Serial.println(MySSID);
// Waiting for Wifi connect
if (WiFiMulti.run() != WL_CONNECTED) {
delay(500);
Serial.print(“Connecting…”);
if (WiFiMulti.run() == WL_CONNECTED) {
Serial.println("");
Serial.print("WiFi connected. ");
Serial.print("IP address: ");
Serial.println(WiFi.localIP());
// Setup button
// Button uses the built-in pull up register.
pinMode(BUTTON1_PIN, INPUT_PULLUP); // INPUT_PULLUP so no need a 10K resistor
pinMode(BUTTON2_PIN, INPUT_PULLUP); // INPUT_PULLUP so no need a 10K resistor
pinMode(BUTTON3_PIN, INPUT_PULLUP); // INPUT_PULLUP so no need a 10K resistor
pinMode(RELAY1_PIN, OUTPUT);
pinMode(RELAY2_PIN, OUTPUT);
pinMode(RELAY3_PIN, OUTPUT);
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
digitalWrite(LED1, HIGH);
delay(200);
digitalWrite(LED2, HIGH);
delay(200);
digitalWrite(LED3, HIGH);
delay(200);
digitalWrite(LED1, LOW);
digitalWrite(LED2, LOW);
digitalWrite(LED3, LOW);
delay(500);
delay(200);
delay(200);
delay(200);
config1.setEventHandler(button1Handler);
config2.setEventHandler(button2Handler);
config3.setEventHandler(button3Handler);
button1.init(BUTTON1_PIN);
button2.init(BUTTON2_PIN);
button3.init(BUTTON3_PIN);
// server address, port and URL
webSocket.begin(“iot.sinric.com”, 80, “/”);
// event handler
webSocket.onEvent(webSocketEvent);
webSocket.setAuthorization(“apikey”, MyApiKey);
// try again every 5000ms if connection has failed
webSocket.setReconnectInterval(5000); // If you see ‘class WebSocketsClient’ has no member named ‘setReconnectInterval’ error update arduinoWebSockets
Serial.println(“Not Connected”);
else
Serial.println(" Connected");
webSocket.loop();
button1.check();
button2.check();
button3.check();
if (isConnected) {
uint64_t now = millis();
// Send heartbeat in order to avoid disconnections during ISP resetting IPs over night. Thanks @MacSass
if ((now - heartbeatTimestamp) > HEARTBEAT_INTERVAL) {
heartbeatTimestamp = now;
webSocket.sendTXT("H");
void setPowerStateOnServer(String deviceId, String value) {
JsonObject& root = jsonBuffer.createObject();
#endif
DynamicJsonDocument root(1024);
#endif
root[“deviceId”] = deviceId;
root[“action”] = “setPowerState”;
root[“value”] = value;
StreamString databuf;
root.printTo(databuf);
#endif
serializeJson(root, databuf);
#endif
webSocket.sendTXT(databuf);
void button1Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println(“EVENT1”);
switch (eventType) {
case AceButton::kEventPressed:
Serial.println(“kEventPressed”);
setPowerStateOnServer(device_ID_1, “ON”);
break;
case AceButton::kEventReleased:
Serial.println(“kEventReleased”);
setPowerStateOnServer(device_ID_1, “OFF”);
break;
void button2Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println(“EVENT2”);
setPowerStateOnServer(device_ID_2, “ON”);
break;
setPowerStateOnServer(device_ID_2, “OFF”);
break;
void button3Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println(“EVENT3”);
setPowerStateOnServer(device_ID_3, “ON”);
break;
setPowerStateOnServer(device_ID_3, “OFF”);
break;
