Pessoal, boa tarde.
Sou novo no forum e no Arduino e precisava muito da ajuda de vocês com um código pronto copiado da internet.
Tenho no código a mostra de horário e temperatura. Mas precisava também que exibisse a data. Alguem pode me ajudar?
O Video em questão:
O Código:
#include <DS3232RTC.h>
#include <TimeLib.h>
#include <Time.h>
#include <Wire.h>
#include <FastLED.h>
#define NUM_LEDS 114 // 474 +2 Number of LED controlled
#define COLOR_ORDER GRB // Define color order for your strip
#define LED_PIN 6 // Data pin for led comunication
#define DST_PIN 5 // Define DST adjust button pin
#define MIN_PIN 4 // Define Minutes adjust button pin
#define HUR_PIN 3 // Define Hours adjust button pin
CRGB leds[NUM_LEDS]; // Define LEDs strip
// 0,0,0,0
// 1,1,1,1
// 1 2 3 4 5 6 7 8 9 10111213141516171819202122232425262728
byte digits[12][28] = {{0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1}, // Digit 0
{0,0,0,0,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1}, // Digit 1
{1,1,1,1,1,1,1,1,1,1,1,1,0,0,0,0,1,1,1,1,1,1,1,1,0,0,0,0}, // Digit 2
{1,1,1,1,1,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1}, // Digit 3
{1,1,1,1,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,0,0,0,0,1,1,1,1}, // Digit 4
{1,1,1,1,0,0,0,0,1,1,1,1,1,1,1,1,0,0,0,0,1,1,1,1,1,1,1,1}, // Digit 5
{1,1,1,1,0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1}, // Digit 6
{0,0,0,0,1,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1}, // Digit 7
{1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1}, // Digit 8
{1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,0,0,0,0,1,1,1,1,1,1,1,1}, // Digit 9 | 2D Array for numbers on 7 segment
{1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0}, // Digit *0
{0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,0,0,0,0}}; // Digit C
bool Dot = true; //Dot state
bool DST = false; //DST state
bool TempShow = true;
int last_digit = 0;
// int ledColor = 0x0000FF; // Color used (in hex)
long ledColor = CRGB::DarkOrchid; // Color used (in hex)
//long ledColor = CRGB::MediumVioletRed;
//Random colors i picked up
long ColorTable[16] = {
CRGB::Amethyst,
CRGB::Aqua,
CRGB::Blue,
CRGB::Chartreuse,
CRGB::DarkGreen,
CRGB::DarkMagenta,
CRGB::DarkOrange,
CRGB::DeepPink,
CRGB::Fuchsia,
CRGB::Gold,
CRGB::GreenYellow,
CRGB::LightCoral,
CRGB::Tomato,
CRGB::Salmon,
CRGB::Red,
CRGB::Orchid
void setup(){
Wire.begin();
FastLED.addLeds<WS2812B, LED_PIN, RGB>(leds, NUM_LEDS);
LEDS.setBrightness(75); // Set initial brightness
pinMode(DST_PIN, INPUT_PULLUP); // Define DST adjust button pin
pinMode(MIN_PIN, INPUT_PULLUP); // Define Minutes adjust button pin
pinMode(HUR_PIN, INPUT_PULLUP); // Define Hours adjust button pin
// Get time in a single number, if hours will be a single digit then time will be displayed 155 instead of 0155
int GetTime(){
tmElements_t Now;
RTC.read(Now);
//time_t Now = RTC.Now();// Getting the current Time and storing it into a DateTime object
int hour=Now.Hour;
int minute=Now.Minute;
int second =Now.Second;
if (second % 2==0) {Dot = false;}
else {Dot = true;};
return (hour*100+minute);
// Convert time to array needet for display
void TimeToArray(){
int Now = GetTime(); // Get time
int cursor = 114; // last led number
// Serial.print("Time is: ");Serial.println(Now);
if (DST){ // if DST is true then add one hour
Now+=100;
// Serial.print("DST is ON, time set to : ");Serial.println(Now);
if (Dot){leds[57]=ledColor;
leds[56]=ledColor;}
else {leds[57]=0x000000;
leds[56]=0x000000;
for(int i=1;i<=4;i++){
int digit = Now % 10; // get last digit in time
if (i==1){
// Serial.print("Digit 4 is : “);Serial.print(digit);Serial.print(” ");
cursor = 86;
for(int k=0; k<=27;k++){
// Serial.print(digits[digit][k]);
if (digits[digit][k]== 1){leds[cursor]=ledColor;}
else if (digits[digit][k]==0){leds[cursor]=0x000000;};
cursor ++;
// Serial.println();
if (digit != last_digit)
cylon();
ledColor = ColorTable[random(16)];
last_digit = digit;
else if (i==2){
// Serial.print("Digit 3 is : ");Serial.print(digit);Serial.print(" ");
cursor =58;
cursor ++;
else if (i==3){
// Serial.print("Digit 2 is : ");Serial.print(digit);Serial.print(" ");
cursor =28;
cursor ++;
else if (i==4){
// Serial.print("Digit 1 is : ");Serial.print(digit);Serial.print(" ");
cursor =0;
cursor ++;
Now /= 10;
// Convert temp to array needet for display
void TempToArray(){
tmElements_t tm;
RTC.read™;
if (tm.Second != 27) {
TempShow = false;
return;
TempShow = true;
int t = RTC.temperature();
int celsius = (t / 4.0) * 100;
Serial.print("Temp is: ");Serial.println(celsius);
leds[57]=0x000000;
leds[56]=0x000000;
int digit = celsius % 10; // get last digit in time
if (i==1){
cursor = 86;
Serial.print(digits[11][k]);
if (digits[11][k]== 1){leds[cursor]=ledColor;}
else if (digits[11][k]==0){leds[cursor]=0x000000;};
cursor ++;
Serial.println();
else if (i==2){
cursor =58;
Serial.print(digits[10][k]);
if (digits[10][k]== 1){leds[cursor]=ledColor;}
else if (digits[10][k]==0){leds[cursor]=0x000000;};
cursor ++;
Serial.println();
else if (i==3){
cursor =28;
cursor ++;
Serial.println();
else if (i==4){
cursor =0;
cursor ++;
Serial.println();
celsius /= 10;
void DSTcheck(){
int buttonDST = digitalRead(2);
// Serial.print("DST is: ");Serial.println(DST);
if (buttonDST == LOW){
if (DST){
DST=false;
// Serial.print("Switching DST to: ");Serial.println(DST);
else if (!DST){
DST=true;
delay(500);
void TimeAdjust(){
int buttonH = digitalRead(HUR_PIN);
int buttonM = digitalRead(MIN_PIN);
if (buttonH == LOW || buttonM == LOW){
delay(500);
tmElements_t Now;
RTC.read(Now);
int hour=Now.Hour;
int minutes=Now.Minute;
if (buttonH == LOW){
if (Now.Hour== 23){Now.Hour=0;}
else {Now.Hour += 1;};
}else {
if (Now.Minute== 59){Now.Minute=0;}
else {Now.Minute += 1;};
RTC.write(Now);
/* coool effect function*/
void fadeall() { for(int i = 0; i < NUM_LEDS; i++) { leds[i].nscale8(250); } }
void cylon () {
static uint8_t hue = 0;
Serial.print(“x”);
// First slide the led in one direction
// Set the i’th led to red
leds[i] = CHSV(hue++, 255, 255);
// Show the leds
FastLED.show();
// now that we’ve shown the leds, reset the i’th led to black
// leds[i] = CRGB::Black;
fadeall();
// Wait a little bit before we loop around and do it again
delay(10);
Serial.print(“x”);
// Now go in the other direction.
for(int i = (NUM_LEDS)-1; i >= 0; i–) {
// Show the leds
FastLED.show();
fadeall();
delay(10);
void loop() // Main loop
DSTcheck(); // Check DST
TimeAdjust(); // Check to se if time is geting modified
TimeToArray(); // Get leds array with required configuration
TempToArray();
FastLED.show(); // Display leds array
if (TempShow == true) delay (8000);
