Boa tarde,
Estou tendo dificuldade em um trabalho da escola, onde pretendo controlar um driver monster shield com comunicação via bluetooth.
Cheguei a seguinte programação:
#define BRAKE 0
#define CW 1
#define CCW 2
#define CS_THRESHOLD 15
//MOTOR 1
#define MOTOR_A1_PIN 7
#define MOTOR_B1_PIN 8
//MOTOR 2
#define MOTOR_A2_PIN 4
#define MOTOR_B2_PIN 9
#define PWM_MOTOR_1 5
#define PWM_MOTOR_2 6
#define CURRENT_SEN_1 A2
#define CURRENT_SEN_2 A3
#define EN_PIN_1 A0
#define EN_PIN_2 A1
#define MOTOR_1 0
#define MOTOR_2 1
#include <SoftwareSerial.h>
#define RX 0
#define TX 1
SoftwareSerial bluetooth(RX, TX);
short usSpeed = 150; //default motor speed
unsigned short usMotor_Status = BRAKE;
pinMode(MOTOR_A1_PIN, OUTPUT);
pinMode(MOTOR_B1_PIN, OUTPUT);
pinMode(MOTOR_A2_PIN, OUTPUT);
pinMode(MOTOR_B2_PIN, OUTPUT);
pinMode(PWM_MOTOR_1, OUTPUT);
pinMode(PWM_MOTOR_2, OUTPUT);
pinMode(CURRENT_SEN_1, OUTPUT);
pinMode(CURRENT_SEN_2, OUTPUT);
pinMode(EN_PIN_1, OUTPUT);
pinMode(EN_PIN_2, OUTPUT);
bluetooth.begin(9600);
Serial.begin(115200);
Serial.println(“Begin motor control”);
Serial.println(); //Print function list for user selection
Serial.println(“Enter number for control option:”);
Serial.println(“1. STOP”);
Serial.println(“2. FORWARD”);
Serial.println(“3. REVERSE”);
Serial.println(“4. READ CURRENT”);
Serial.println("+. INCREASE SPEED");
Serial.println("-. DECREASE SPEED");
Serial.println();
void loop (){
verificaBluetooth();
char user_input = bluetooth.read();
void verificaBluetooth(){
if (bluetooth.available()){
digitalWrite(EN_PIN_1, HIGH);
digitalWrite(EN_PIN_2, HIGH);
if (user_input =='1')
Stop();
else if(user_input =='2')
Forward();
else if(user_input =='3')
Reverse();
else if(user_input =='+')
IncreaseSpeed();
else if(user_input =='-')
DecreaseSpeed();
else
Serial.println("Invalid option entered.");
void Stop()
Serial.println(“Stop”);
motorGo(MOTOR_1, usMotor_Status, 0);
motorGo(MOTOR_2, usMotor_Status, 0);
void Forward()
Serial.println(“Forward”);
usMotor_Status = CW;
motorGo(MOTOR_1, usMotor_Status, usSpeed);
motorGo(MOTOR_2, usMotor_Status, usSpeed);
void Reverse()
Serial.println(“Reverse”);
usMotor_Status = CCW;
void IncreaseSpeed()
usSpeed = usSpeed + 10;
if(usSpeed > 255)
usSpeed = 255;
Serial.print("Speed +: ");
Serial.println(usSpeed);
void DecreaseSpeed()
usSpeed = usSpeed - 10;
if(usSpeed < 0)
usSpeed = 0;
Serial.print("Speed -: ");
void motorGo(uint8_t motor, uint8_t direct, uint8_t pwm)
if(motor == MOTOR_1)
if(direct == CW)
digitalWrite(MOTOR_A1_PIN, LOW);
digitalWrite(MOTOR_B1_PIN, HIGH);
else if(direct == CCW)
digitalWrite(MOTOR_A1_PIN, HIGH);
digitalWrite(MOTOR_B1_PIN, LOW);
else
analogWrite(PWM_MOTOR_1, pwm);
else if(motor == MOTOR_2)
if(direct == CW)
digitalWrite(MOTOR_A2_PIN, LOW);
digitalWrite(MOTOR_B2_PIN, HIGH);
digitalWrite(MOTOR_A2_PIN, HIGH);
digitalWrite(MOTOR_B2_PIN, LOW);
else
analogWrite(PWM_MOTOR_2, pwm);
É certo que parte dessa programação peguei fuçando na internet, mas na hora de colocar com bluetooth, não consigo rodar o motor, alguém poderia ajudar?
