o codigo não funciona no nodeMCU 1.0 alguem poderia me ajudar? ja tentei de tudo e precisava fazer ele rodar, quando ele estava no arduino mega funcionava normalmente.
CODIGO:
// Pin definitions
define Hall_sensor 6 // Pino digital 2
// Constants definitions
const float pi = 3.14159265; // Numero pi
int period = 5000; // Tempo de medida(miliseconds)
int delaytime = 2000; // Time between samples (miliseconds)
int radius = 147; // Raio do anemometro(mm)
// Variable definitions
unsigned int Sample = 0; // Sample number
unsigned int counter = 0; // magnet counter for sensor
unsigned int RPM = 0; // Revolutions per minute
float speedwind = 0; // Wind speed (m/s)
float windspeed = 0; // Wind speed (km/h)
// Set the pins
pinMode(6, INPUT);
digitalWrite(6, HIGH); //internall pull-up active
//Start serial
Serial.begin(9600); // sets the serial port to 9600 baud
Sample++;
Serial.print(Sample);
Serial.print(": Start measurement…");
windvelocity();
Serial.println(" finished.");
Serial.print("Counter: “);
Serial.print(counter);
Serial.print(”; RPM: “);
RPMcalc();
Serial.print(RPM);
Serial.print(”; Wind speed: ");
//print m/s
WindSpeed();
Serial.print(windspeed);
Serial.print(" [m/s] ");
//print km/h
SpeedWind();
Serial.print(speedwind);
Serial.print(" [km/h] ");
Serial.println();
delay(delaytime); //delay between prints
// Measure wind speed
void windvelocity(){
speedwind = 0;
windspeed = 0;
counter = 0;
attachInterrupt(0, addcount, RISING);
unsigned long millis();
long startTime = millis();
while(millis() < startTime + period) {
void RPMcalc(){
RPM=((counter)*60)/(period/1000); // Calculate revolutions per minute (RPM)
void WindSpeed(){
windspeed = ((4 * pi * radius * RPM)/60) / 1000; // Calculate wind speed on m/s
void SpeedWind(){
speedwind = (((4 * pi * radius * RPM)/60) / 1000)*3.6; // Calculate wind speed on km/h
void addcount(){
counter++;
FIM DO CODIGO.
queria muito que ele rodasse no nodeMCU.
